Usually taking your foot off the gas will cure it. LOLAnyone seen this before? At idle my tach bounces from 500 to as high as 3000 RPM all by itself. Sorry couldn't get the video to load.
Yes I reluctantly tried that . 8 kms on it, must be worn out lolUsually taking your foot off the gas will cure it. LOL
Other than that if it keeps up then probably a sensor fault.
Here's what it looks like.
If you're trying to upload a vid Dan you will have to use Youtube or something similar. Upload to that first and then paste the link back in here.
Thanks will do.If you're trying to upload a vid Dan you will have to use Youtube or something similar. Upload to that first and then paste the link back in here.
Done. ThanksGoogle drive has worked for me if you have that Dan. Likely just as easy on YouTube but I haven’t tried it. Don’t know about YouTube uploading but you can set view permissions easily on google drive.
I will get it looked at in the spring when the car comes out of storage and post the results.Interesting issue you have there Dantanman. I would be interested in knowing the diagnosis when you get it.
