That's what most people get. We've had two customer get a full wrap. Not cheap and takes a long time.I will certainly go visit for a consult when I have the car. I just want the clear coat protection on all of the leading edge areas. My brother-in-law had his Mustang Bullit done and it is invisible but protects the rockers and front facia. That is what I want on my C8 too.
I second this post. I did the entire front and mirrors and headlights in the 3M and it scratches easily and gets cloudy. My rear quarters behind the the rear tire were done with Suntek and it is far superior and as the installer told me actually can repair small scratches itself by heating up in sunlight. Not sure if that's the exact science but the 3M stuff has almost no option to fix it.If you get a Paint Protection Film (PPF), do not go with a company that uses 3M. It is an inferior product to Suntek and Xpel. The guy we use used to have 3M, but made the switch a few years ago and it blown away by the difference (so are our customers).
We use Reflection Auto + Glass on Ward Street in Port Hope, Ontario. It's a small Mom and Pop shop, owned and operated by Mark and his wife (whos name is slipping my mind at this moment).
Mark will literally go out of his way to ensure a customer is happy with the final result.
The only thing he doesn't do right now is ceramic coating.
More info here:
Reflection Glass & Accessories · 330 Ward St, Port Hope, ON L1A 4A6, Canada
★★★★★ · Glass shopgoo.gl
If you are serious about having your car wrapped, give him a call via the link above and tell him I sent you his way.
thank you Sir I wont forget. I'm in Windsor, well seeIf you get a Paint Protection Film (PPF), do not go with a company that uses 3M. It is an inferior product to Suntek and Xpel. The guy we use used to have 3M, but made the switch a few years ago and it blown away by the difference (so are our customers).
More info here:
3M has improved significantly with the PRO level PPF same as Xpel self healing, no yellowing etc.I second this post. I did the entire front and mirrors and headlights in the 3M and it scratches easily and gets cloudy. My rear quarters behind the the rear tire were done with Suntek and it is far superior and as the installer told me actually can repair small scratches itself by heating up in sunlight. Not sure if that's the exact science but the 3M stuff has almost no option to fix it.
I was quoted $1200 for the front and $220 for the side air vents. Ceramic Pro Gold. Lifetime warranty, 4 layers of 9H and one layer of Light (Whatever all that means )That Kavaca sounds interesting. Could not really check it out while still offshore but I wonder how well it compares cost-wise
