I am trying to get a good pedal on my brakes. New callipers, lines etc
New master cylinder but I still can’t get a good pedal. Any comments appreciated
I had the exact same issue as you. I had installed new master cylinder, new lines, and ‘new’ AC delco calipers. At first I had a few leaks around the fittings but eventually got it bleed but a few days later my brakes would be spongy. Turns out my calipers were leaking. After 3 sets of calipers I finally gave up and went with Wilwoods and haven’t had a problem since.Thanks for the info. I have bleed them several times and still don’t have much of a pedal. Good to know about pumping because when I did this I got a bit of a pedal but goes away which makes me believe air still in the system. I will keep at it.
