A few years ago, GM had a recall regarding the Active Handling in the C6 cars. What was that all about? Sounded serious from what I recall.
I’ve never had that in the 4 years I’ve had my C6 Keith. My issue is an intermittent air bag light since I’ve had it.
Well,that’s not the issue. And in all honesty,it’s not that much of a concern anymore.Hi Mikey
I had the same issue on my GS. Turned out it was the connector under the drivers seat, it would wiggle just enough when using the power seats to trigger the light from time to time. I wrapped a zip tie around the connector and the air bag light has not been an issue since.
Keith for $100 per hour you expected perfection? Lucky you caught it before it flattened your battery.
Those little battery connections are in a awkward spot but no excuse for that.
My son was in at the Ford dealer for an oil change. There was a very upset woman who had her car towed in. She had just had a brake job done and the front calliper came right off and jammed in the wheel assembly, ruining that wheel. My son said she looked scared rather than angry. I can understand that.
Hey anybody out there with information on a 2004 Corvette with 149000 miles on it never had any problems with this car recently replaced one of the tire sensors couple months went by and the reduced engine power came up along with traction control going on and off replace the throttle sensor ran fine for a couple weeks now the reduced engine power signal is up again and can't go over 30 miles an hour any suggestions?
