H1 Hummers have a big doughnut insert that goes inside the tire. This is how they are considered “run flats”. They are hell to get in and out but do work.
This stuff has long been pulled off mine as the truck also has the onboard air compressor and lines to the tires. So a substantial leak is not a problem. You can deflate and inflate on the fly.
You can see the airline coming out through the hub and running over to the tire in the photo. There is a regular valve stem valve and cap on there well to air up from a remote air supply if needed. The connection to the hub in the center is on a quick connect fitting as well and pops right off of you have a system leak and begin losing air in the tire. It’s a pretty amazing set up. Very robust but simple.
And yes.... that’s a Chuck Norris bobblehead on the dash.
