Rocker arms
Can I install 1.6 roller rockers in my 82 corvette 350 crossfire engine without running into any major problems ?
You should be fine it depends on how much lift your cam has. To be sure install 2 light valve springs one 1 cyl . Turn the engine over and check the valve to piston clearance.
