about 3 hours work, make sure you check the bolts on the tilt mechanism inside the column for tightness, they loosen up with time, also they all fit from '69 thru ' 76, I believe '77 went to the headlight dimmer on the column
Correct. '77 is a different column; only year that had the wiper switch on the signal leaver.
