Hi guys....I currently have Contenential Extreme Contact summer tires. The rear trend depth is 10mm and the front 4mm. The fronts will need to be changed before the rear. I was planning on changing to Dunlop Direzza DZ102 on all four at some point but now I know the rears have a lot of life left and I don’t want to prematurely change them. So.....the question is do I have to replace the front tires with the same make and model as the rears or could I get away with mixing them up....I expect I know the answer but I would like your thoughts. I do not race on or off track but like performance.
Cheers
Kevin
Cheers
Kevin
