So..I cleaned my MAF sensor and Throttle Body a week or so ago and when I put it all back together and started the engine, I ended up with several codes. One being "reduced engine power", After some research I deduced that it was an issue with the throttle position sensor. Turn the car on and within a couple seconds it goes to 2000 RPM and stays there. Clear the codes through the DIC and it goes back to idle for a couple seconds then back to 2K again. I bought a new TPS (AC Delco) and installed it but still the same thing. I have tried several of the recommendations off forums and Youtube, but to no avail. Surely, someone here has encountered this issue at some point and has had the issue fixed.
I would like to know what has to be done to reset the TPS or fix the issue, as I am itching to get out on the road.
I am the furthest thing from an electrical technician, but would appreciate some insight on how to remedy this problem.
I thank you all in advance,
