Rear end leaking
Where is the rear end leaking? These cars are notorious for leaking seals on both side of the housing. After having mine repaired under warranty and the rear end continued to leak.
I discovered that the GM mechanic reused the "crush" washers when refilling the gear case. These washers are stupid expensive but need to be replaced when changing the rear end lube. Has your car had service lately?
Good luck and Race Ready Garage will sort it for you.
I just had it in for a brake flush and they told me rear end is leaking very small. They said its ok for the summer but it should be fixed in the spring they didnt say where.
