Shayne
You're a Regular 2 You're 10 Completionist Award
Dec 1, 2010
441
28
ok here goes. I disconnected my neg battery cable to reboot my pioneer aph 8400 audio/video system, hereby referred to as the deck. wwhen I reconnected my neg cable, my power top will no longer go up or down. there is no message on the driver info center, as usually it will give an alarm and message. fuses look good under the hood haven't got to the ones under the dash yet. any other ideas would be appreciated, going to spearfish on wed.
pretty bad I know, answering myself. I went out to the garage, disconnected the battery again. reconnected, and sat in the car with the owners manual. windows were down when I disconnected the battery. so as I sit there I put the windows up, then pushed the top up button, and what do you know the windows went down and then the top came up. does anyone know if the windows actually have anything to do with this? anyway the top works so that's the bottom line. keep this in mind if it happens to you
