I am failing to get the Performance Timer to work. I have changed the start and end times. I have tried it in all drive modes. It only worked for me once when I was in Sport mode and Race 1. I’m confused as to what I am doing wrong.
Did you hit the traction control button twice to put it in competition mode? Then hold the brake, floor it, should go to 3500 rpm, let go of the brake and away you go! Timer should be automatic. I had trouble figuring it out at first too.I am failing to get the Performance Timer to work. I have changed the start and end times. I have tried it in all drive modes. It only worked for me once when I was in Sport mode and Race 1. I’m confused as to what I am doing wrong.
Yes, tried sport and track modes. hit the traction control button twice and the brake and gas to 3500rpms. Timer only worked once for me. Im sure the problem is between the driver’s seat and the steering wheel.Did you hit the traction control button twice to put it in competition mode? Then hold the brake, floor it, should go to 3500 rpm, let go of the brake and away you go! Timer should be automatic. I had trouble figuring it out at first too.
That would be slower than switching the units to US (Imperial) and using 0-60 mph since 100 kph is 62.137 mphDo you mean the 0-100kph timer?
Thanks! Going to a track and give it another tryIt says "Competition mode" in the display when you hit the traction control twice.
It will NOT launch if your foot is not really hard on the brake pedal. Not just hard, but really hard.
You don't rev to 3500. Your foot is to the floor on both pedals and the car revs to 3500.
Were you talking about the PDR timing by chance?I am failing to get the Performance Timer to work. I have changed the start and end times. I have tried it in all drive modes. It only worked for me once when I was in Sport mode and Race 1. I’m confused as to what I am doing wrong.
Talking about this…Were you talking about the PDR timing by chance?
I was just looking in the manual to see if there was a way to record date and time in the display.
It doesn't seem to, but I did notice that it will record your 0 to 100 times if the overlay is set to "Timing"
True, the timer works in any mode, but Launch control does not.The performance timer should work in every mode- it works for me in every mode from Weather to Sport. Could it be that you're not past the break in kms so it won't work yet? Just a thought but I don't know for sure- I see your projected mileage at 395 but can't see your odometer.
I’m at ~1600kmThe performance timer should work in every mode- it works for me in every mode from Weather to Sport. Could it be that you're not past the break in kms so it won't work yet? Just a thought but I don't know for sure- I see your projected mileage at 395 but can't see your odometer.
Well if I can’t get this to work, I’m scraping the car! Come on Z06! I want one. Oh yes I do!Set it up for some big pullsView attachment 86102
