Aug 24, 2022
52
42
2021 c8 corvette
Hi Guys I installed the Paragon lowering collars last week the car looks awesome lowered. The issue I'm having is different heights on each side from floor to underside of fender. I know I installed the collars correctly and bled the front lift. I've run the hydraulic front lift through a 10 cycle and nothing gives me a symmetrical floor to fender height. One side is 26.5'' plus 2/16 and the other side is 26.25'' plus 2/16 .......Just wondering if anyone has a fix for this.
Did you check the measurements before the alteration?
I have changed out suspension parts for years and after struggling to
get both sides the same on a few realized I should check before the change out.
Most of my cars were out 1/4" side to side from factory. I always measure at wheel well centre.
When you lower the car the difference becomes more noticeable.
Unfortunately I did not think of measuring before lowering it. The passenger side looks lower than the driver side. This is the tip of the front splitter 5 .3'' ....How could that be, this is what it is from factory.
