Nope . Never. Having said that though….yes , from an AI search…..Who gets their oil analysed? How often?
There is a known issue of oil dilution reported by some C8 owners. This is common in a lot of vehicles with direct injection. Reports of this problem being over the max recommended 2% fuel levels in the oil from some C8 owners. I have only seen excessive levels reported on 5.5L. I am planning to do analysis on my 5.5L to monitor fuel in the oils and other contaminants, metals etc. I have only seen reports of this problem from US forums and Corvette bloggers and nothing from GM.Best oil check is for the mechanic to run his finger along the bottom of the pan and look to see if it comes out all shiny.
Caught a connecting rod bolt in the pan once. Just routine oil change on a Det Die in preparation for a long haul trip. Would have never made it there.
Nothing against oil analysis. Just overkill in 99.9% of engines unless a known problem is occurring since manufacture.
If you are tracking then the engine is under more duress and then it might be advisable.
Doing an analysis on a brand new engine is fairly useless as it would be normal to have a little extra metal from break in. If you want to baseline an engine then note a fourth or fifth oil change analysis and then maybe check it every four or five changes after that.
Did they measure fuel in the oil? What % did they indicate?I did my first sample a few months ago on my initial 3k kms SR. I may do another one because I had ordered 2 kits. My reasons was to measure particle count for my new oil filter, however they can't do that for motor oil. Bummer.
Amsoil Canada in Edmonton.
Here's my 3k kms analysis. First timer here to see this type of report.Did they measure fuel in the oil? What % did they indicate?
https://www.gofundme.com/????If you guys want to pony up, I'll do my car for you. Once the results are in, you can determine if you need the extended warranty or not...
AFAIK mostly reported on 5.5LIs this fuel dilution an issue for the 6.2 litre Stingray or just the 5.5 litre Z06?
Ya…. Right….., lol.Glad I don't have a Z06.
