Fire22
Fire22
Member
Feb 6, 2009
50
Near Winnipeg
2001 coupe
Last winter I started building an oil catch can (I made 3). I finished up and have one installed on the car now with about 300km on it. Here are some pictures.
This winter I would like to improve the look under the hood by changing the hoses and clamps on the catch can, I might even remove the red paint and polish it.
I just used the existing M10 threaded holes in the cylinder head to mount it.
Fire22
Fire22
Member
Feb 6, 2009
50
Near Winnipeg
2001 coupe
Here is the oil that was trapped and not put into the intake. This is about 300km worth of filtering.
The can unscrews for easy inspection and cleaning.
Riley P
Riley P
Wish me a Happy Birthday
Jan 11, 2009
11,086
1,971
Saska-ba-toon!
2000 Z51
SK
Sorry to not know a lot about the catch can, but where does the inlet hose come from and the outlet hose go? This may help my understanding of where the oil comes from and why we need one. Thanks! It looks awesome.
Fire22
Fire22
Member
Feb 6, 2009
50
Near Winnipeg
2001 coupe
In simple terms, its a filter between the PCV valve and the intake. Engines produce internal pressure in the crank case area and it is relieved through the PCV system, it (internal gasses and oil mist) is piped through the PCV valve and into the intake manifold and used for combustion. The catch can helps remove some of the oil mist, the oil coalesces on the filter material and can internals and stays in the can. Some who have removed LS1 intake manifolds have noticed excessive oil buildup in the manifold, it comes from the PCV system.
The inlet hose is connected to the PCV valve and the outlet goes to the intake.
If you do a search on Oil Catch Cans you can get a better explanation and you can purchase them from different vendors. I was energetic, interested in a project and cheap so I built my own.
Hope this helps explain it.
ctdrl-1
ctdrl-1
Well-Known Member
Jan 12, 2009
521
Saskatoon, Sask
WOW!, I think you may have missed your calling, you seem to have skills with your car that I can even dream of.
If your as good at your job as you are with the cars I think everyone in MB can sleep a little better.
Brent:canada:
