Hello, I picked up a unit today at CTC, I know it's only a 1,000 amp crank but the 2019 battery crank is 750 cold crank amps so does anyone feel that this unit won't be sufficient??
Ok, I guess I wrote this post up wrong. I purchased it to use in case the battery goes flat and requires a boost. So I am looking for opinions if anyone has used this model or is a larger amperage unit required to boost a C7?
Did your '19 come with the 'Battery Maintenance Pkg'?Oh sorry, it's a battery booster and it's aC7 Grand sport.
The booster you bought will have more than enough power to boost your vette if the battery goes flat, But buy a battery maintainer .Hook it in when you park it and leave it until spring.. It will only give the battery a charge when it is required and monitor it when no charge is needed...Ok, I guess I wrote this post up wrong. I purchased it to use in case the battery goes flat and requires a boost. So I am looking for opinions if anyone has used this model or is a larger amperage unit required to boost a C7?
