My crossfire has sat for years bringing it back to life.
1984 Z51
I had a stroke then retina detached had to get surgery. Corvette sat for years. Will be firing up the old pig when the snow leaves. Planning on finally doing the ram air mod for crossfires. Will need to remove the fuel before fire up. I bought a hose from crappy tire to remove the fuel.
Glad to hear your health has improved so you can start driving your car again! If your C4 has sat for 5 years or more it is recommended and you can double check your owners manual, that you replace all the fluids including differential, coolant, transmission, oil and check the brake fluid as well just to be safe!
