Mike decisions decisions. Another $98K and you get an entire new car, tires and all. Trade in allowance for your beast and you are up cash.
I would consider it but,,,,we’re about how much apart on it ?? I’ll be wanting one of those repair tools so,don’t forget to bring one to Cochrane. Or,I’ll have Spence get it for me come Ponoka.My ZR1 has new tires on it......... buy it!
Non RF you just need one of my tire repair tools...... best way to do it.
B
View attachment 14603 I just came from Kal-Tire on Edmonton trail here in Calgary. This is what I got for a quote for PS 4s. This is for normal tires. Not the zero pressure.
I did read that in the description at Kal tire. I don’t see me getting these ones.Need a heated garage for these tires though. Michelin warns that they will crack under -7 degrees if they are looked at sideways.
The Pilot Sport 4S excels in warm dry and wet conditions, so like all Max Performance Summer tires, is not intended to be serviced, stored nor driven in near- and below-freezing temperatures, through snow or on ice.Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels or using them to support, roll or drive a vehicle.
What if your garage heater goes..... no tires should crack in the cold. B
It is probably worth high 60's now.....
B
You don't need a heated garage, you just shouldn't use them when they're cold.Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner
For most sticky tires it's recommended to keep them warm all the time, but unless you're competing with them, you'll never notice the loss of grip, IMO.
Are you adding the other costs Dennis,or just the tire price? I’m going to stop by there again later and get the quote for Nitto Invos and will post that as well.That seems like the price for ZP's
Have you tried Costco: they carry Michelin tires and both my wife and I put new replacements on our SUVs -way cheaper than anyone else. I believe they have, or can get, HP tires as well.View attachment 14603 I just came from Kal-Tire on Edmonton trail here in Calgary. This is what I got for a quote for PS 4s. This is for normal tires. Not the zero pressure.
