I remove my battery when storing car for the winter. Has anyone used a memory saver to maintain voltage continuity for computer, clock and radio memory when vehicle battery is disconnected for winter storage?
Thanks and whether it would maintain for 6 months is basically why I asked the question. The memory unit that I’m looking at plugs into the OBD port.Never used one as I have a shop with power and use battery maintainers on all my stored vehicles. Memory savers are typically used for short term battery disconnects ie: changing a battery, etc. The memory saver battery is normally a 9V transistor type battery. Not sure if it would maintain charge for 6+ months running the computer, clock, etc. which would defeat the purpose if it didn't last. If you do use one, make sure it is connected to an un-switched cig lighter.
Hi Canuckguy. Thanks for the info and wondering if your car has Nav? Seems that some of the cars with Nav lose the clock after a battery disconnect.Hello DL. I've had my C6 in storage for up to 6 months with the battery out. I only had to reindex the windows and change the speedo from mph to kph. You might want to leave the hood unlatched (down but not fully closed) so you can get back in.
Area Z51 thanks for the info and for the offer of the fix file. I’ll remove the battery for storage and won’t bother with a memory saver and hopefully won’t have any clock issues.The battery can be removed, and the only thing you will need to do in the Spring is re-index the windows. As mentioned, leave you hood propped slightly open so you can reconnect your battery for your FOB to work to open your door.
If you have the Nav unit, it is simple to download the fix file on a CD-R and upload in the DVD slot. It's funny to see the fix it file on CD for sale on Ebay for as high as $50.00. I'll make you one for free if you need it in the future.
Just as A FYI, once you download the clock fix, you can disconnect the battery and it will not affect the NAV unit clock, or unit. It will be good to go.
With our 2005, I just hook up a battery tender when the car will be sitting for a long time. I've never had a problem is 9 years. Batteries do get old and need to be replaced a little more often than with the cars in the old days. Perhaps the batteries aren't as well built. Whatever, these cars seem to need a strong battery to handle all the systems. The car had a new battery when we bought it in 2012. 7 years is good. Last year, I put in a new, top of the line Delco battery with a 7 year warranty. It lasted about 7 months and had to be replaced, under warranty this spring. The new one has been fine so far.
This is good to know. I can easily have my C-Tek maintainers hooked up all the time as the electrical outlets in the garage are close to the vehicles. Thanks.I still have original battery mine was born with! It's never been out of car, 15 years and counting.
I have a battery tender connected 24/7 365 days a year unless i'm driving it.
With 5 summer only cars I've found it to be the only way to keep batteries ready to drive.
Also have tenders on my quad and side by side for the same reason.
That's the brand I have always used till my C8 which has a GM tender.For my previous winter stored cars, I have used the Battery Tender Plus without issue
I haven’t and had no trouble. I just put in a garage that stays above freezingI remove my battery when storing car for the winter. Has anyone used a memory saver to maintain voltage continuity for computer, clock and radio memory when vehicle battery is disconnected for winter storage?
