i have a 2007 base, automatic, i have found a used complete NPP exhaust from a 2007 Z06. looking to find out if this will fit my car. also will the Varam cold air intake from the same Z06 fit my car?
I know the Vararam for the LS3 is interchangeable with the LS7 but not sure on your LS2 engine Tom. I sold the Vararam off my 09 to an LS7 owner. The exhaust will fit but you will have to adapt the pipe size up to connect. @RockyPM can chime in here as he retrofitted a Z06 NPP to his base a few years back.
@thomigun The MAF housings are different between the LS2 and the LS3/LS7. The LS2 Vararam uses the stock MAF housing between the throttle body tube and the intake and the LS3/LS7 Vararam moves the MAF into the throttle body tube. You might be able to use it if you got an LS2 Vararam tube or similar sized rubber coupling.
