Hey guys. well its been a long time coming but we are finally moving forward with the build. should be in the car before September. Last year we done a mild heads and cam package on my ls2 and laid down 486 rwhp which was ok. this quickly became boring. so after some long discussions with various vendors I opted for the A&A ysi 10 rib kit from josh at A&A. I'll list the parts below. if anyones got any advice feel free to chime in. hoping to hit 900 rwhp or close to it.
SUPERCHARGER KIT
A&A ls2 10 rib ysi kit with 3.0 pulley and 2.75. going to run the 3.0 this year.
Billet Heavy duty auto tensioner
A&A stage 2 fuel system
A&A second drive with dedicated belt for blower
Innovators west 10% overdrive balancer 8"
Alky control twin nozzle straight meth kit
52mm blow off valve
92# injectors at 4 bar
ENGINE MODS
Fast 102 this is coming off Less then 1500 kms on it $900 if anyone wants it.
all new valve train including timing chain.
Inconel high temp valves
Scoggin dickey stage 2 cnc ported and polished 243 cylinder heads
cam is 231/239.617/.624 113 lsa.
160 stat
kooks 1 3/4 long tube headers with offroad x pipe
corsa sports exhaust
K&N cold air intake also up for sale $350 takes it.
forged 402 stroker kit with wiseco pistons. compression will be bumped to 9.5 to 1
crank rated for 1500 hp
block will be line honed
Fully race balanced rotating assembly
ARP head and main studs
Cometic gaskets and king bearings
RXT twin clutch
Tick adjustable clutch master cylinder
new slave cylinder and throw out bearing
So guys that's the list. I've been told this is a pretty safe setup and should be laying down around 850 rwhp. that's fine for this year. Next year once we do a few drivetrain upgrades ill put on the 2.75 and spin the blower harder. so what do you guys think???
SUPERCHARGER KIT
52mm blow off valve
ENGINE MODS
160 stat
RXT twin clutch
