On the right side of oil pan, there is a ''engine oil level sensor'' there is a black and a brown wire. Try to disconect the switch and see if the message change, if not, you can jump the 2 wires, If it work, your switch is probably defective. Oil will leak when you will pull the switch off so drain some oil or match the repair with an oil change
Good luck
Stephane
