Last weekend, I bleed my brakes on my 2011 grand sport using a vacuum pump at the calipers. Now, when I start my car, the brake pedal sink almost to the floor and the brakes feel weird during driving. Any idea what could be wrong?
Yes, sounds like air in the system. I have been using a Motive pressure bleed system for the past 10 years. It makes bleeding brakes a one man operation that can be done in around and hour. Make sure to replace the tubing after 5 years, it does brake down after time. You will need the correct master cylinder adapter for each vehicle you service. Best of luck, you will love it!Thanks for all the input I received. A few minutes ago, I ordered a Motive brake bleeder to replace my 20+ years old vacuum bleeder. I have done all my other vehicles for the last 20 years using my vacuum bleeder with no issues but I guess I met my match with the Corvette brake system. I will keep posted with the results once I receive my new bleeder.
Never use vacuum bleeder .. use only speed bleeder. (Made in USA )
View attachment 89243 http://www.speedbleeder.com/
Until the Teflon sealer wears off the threads. Then they suck air back in. Gotta keep re-applying it to ensure air doesn’t leak past.Never use vacuum bleeder .. use only speed bleeder. (Made in USA )
Google may be, but experience tells me that’s ‘fake news’The ( speed bleeder screw ) they don't suck the air back never .. google it's your friend
My brakes never done bleed from the day when GM make the car ...but lam going to do it when lput my C6 Z06 brakes in .. here is the explain from the company about how to seal the speed bleederGoogle may be, but experience tells me that’s ‘fake news’
once the sealant wears off, that’s it. They suck air back in around the threads. You must keep reapplying Teflon sealant. No biggie, but that’s fact
yep…it says to reapply the Teflon sealant.My brakes never done bleed from the day when GM make the car ...but lam going to do it when lput my C6 Z06 brakes in .. here is the explain from the company about how to seal the speed bleeder
