JL Audio subwoofer Stealthbox for 2005-2013 Chevrolet C6 Corvette
$420.00
JL Audio SB-GM-VETC6/10W1v3: Stealthbox® for 2005-Up Chevrolet C6...
SB-GM-VETC6/10W1v3
The sixth-generation Corvette is an amazing performance car but it can definitely benefit from a major upgrade in the low-frequency department. This Stealthbox® tucks neatly into the rear corner of the hatch and uses the storage pocket space to gain volume without taking up much hatch space and without interfering with targa top stowage.
10" Single 4 Ohms W1v2 Series Subwoofer Power Handling: Peak: 600 watts RMS: 300 watts Impedance: Single 4 Ohms Customizable Trim Ring Vented Reinforcement Collar Elevated Frame Cooling Technology DMA-Optimized Motor System Insert Molded Suspension / Coil / Terminal Sub-Assembly Floating Cone Attach Method Interlocking Cone and Dust Cap Surround Stress-Relief Enclosure Features: Wired for 4 ohms For 2005-Up Chevrolet C6 Corvette Installs in driver-side corner of the hatch A steel mesh grille is included to protect the subwoofer driver Does not affect storage of Targa Top or access to fuel door and emergency door release Will not fit convertible models
The Hard Data: Contains one 10W1v3-2 in a sealed enclosure. 300 watt power handling. Wired for 2 ohm mono. Installs in driver-side corner of the hatch. A steel mesh grille is included to protect the subwoofer driver. Does not affect storage of Targa Top or access to fuel door and emergency door release. Will not fit convertible or ZR-1 models.
$420.00
SB-GM-VETC6/10W1v3
