Ok, just got my set of “Hockey Pucks” to lock into the oval slots in the frame, and there is lots of information out there on where to put these things, but for all of us that only have your standard lift jack and a set of axle stands, It would be nice to know how to safely put this car up in the air for routing service. I'm not getting under there without axle stands! When you use the jacking location to get the back end up, where do you put the axle stand? I can’t get my axel stands within 10 inches of that jacking spot as the trolly jack is in the way. Everything is covered with close out panels under there so you don’t know if there is a frame rail hidden under that panel, or one of those aluminium Bedford 6 castings. I usually use a lower control arm but they are burred inside those deep back rims... and I’ve seen more robust wish bones in the last chicken I carved.
Funny side note… It sure looked odd watching the front wheel go up as I jacked the back wheel up… lol.
