Has anyone used one of these? It's suppose to bypass the econo mode so that cylinders don't shut off. A buddy of mine knows lots about cars and Corvettes and has 2019 Grand Sport right now. I forget what he called it because he talks over my head about cars. LOL. He wanted me to order one off Amazon because he doesn't have an account. So I did. They run around $400.00? He said when down cylinders isn't good for the motor and can cause problems years down the road. Says gas mileage is just as good too.
Heres the write up about it.
- Full Power all the time. No more shuddering or dropping cylinders.
- Fast and easy Setup. Simply Plug in Range into your OBD-ll port and it instantly begins working to eliminate the AFM system.
- All-Terrain/All Weather. No matter where you go, or how the weather is outside, Range delivers the power and control you need for every situation.
- Safe! The Range doesn't reprogram your factory ECU, and leaves no trace once you remove it.
- Power to the people!!
