info to have a 2021 C8 faster
hope to have a c8
NB
GM don't like to build 1Lt because they said they loose some money on base model, so i was thinking probably the will have more order for 1LT with Z51 compare of the 1LT with non-z51, so probably if i take the z51 package my build will be faster than a non z51 model
what do you think ?
thanks
what do you think ?
thanks
No, it doesn't make a difference. All that matters is whether or not your options are on constraint.
GM builds in the most efficient way. For instance, they only make so many front lifts at a time so they are staggered or salted if you will, through the assembly line. Same with Z51 wings and splitters etc. etc. There may only be a certain amount of pigments available at any given time so they may spread out the reds. etc. etc. etc.
So, no, there is no sure fire way to get a car any faster.
Ok perfect thanks a lot !
The 5k gets you to the front of the line, better than Paying 40K over MSRP.
Not sure if you get to the front of the line. If you want vin number 10 you might, but unless you are a blogger or vlogger you might not get anywhere near the actual 10th car built.
lf you think more options and more money spent go in and build a 3LT with all the bells and whistles say a $110,000 build will in your mind get you to the finish line faster go for it . NOW WHEN YOU ARE SAFE and and just before you get to the last hurtle l dont know between 3000 and 3200 you get your build date tell them you want change a few things like the the car to be built in a 1Lt with the Z51 PKG . You should now have them by the gonads and get it faster. Just an idea but l think my dealer is honest and has all our interests in the same boat as they also got caught with there pants down . Just remember the CCP next time you buy anything mass produced .
Dealers can't change the order or cancel it after it's been accepted for production (status 2000.)
