I took my 2022 HTC in for an oil change this morning to a GM Dealer. Once the work was complete, the rear hatch that covers the engine compartment would not fully close. After taking a look to see what the issue was, we noticed that the cable that retracts the end cap for the passenger side nacelle had snapped and would not fold back into the position required to allow the rear hatch to close. The cable that snapped needs to be ordered but the quick fix was to use several zip ties to hold the end cap in the "roof up" position.
I'd suggest that if you own a HTC, have several 12" long zip ties in your car to use for a quick fix should this problem happen to you while you're in the road.
