Prab
Mar 15, 2018
26
2
Awards
2
Edmonton
1971 Corvette
AB
I bought a used 1971 hood to put on my corvette. I also bought a new 1971 hood support to pair with the hood, but the support appears to be too long. When I bolt the support in place and try to lift the hood up, the support isn't able to extend all the way to lock so the hood doesn't stay up. I think the holes in my hood are not the correct distance for a 71 hood, so I'm having trouble figuring out which hood support to use with it. From my understanding, there are three different hood supports I can try: 68 hood support, 69-71 hood support, and 72-73 early hood support. Does anyone know the length of the extension for the 68 hood support and 72-73 early hood support? I need a support that has an extension length less than 15 inches.
I have also measured the distance from the top of the hood to the bolt holes (roughly 14 inches). If anyone has a hood with a similar distance, could you let me know which hood support you're using?
Any help you can provide would be greatly appreciated.
Prab
Norm07
Feb 11, 2018
30
36
Beamsville
2000 C5 Coupe
These are off my April 1971 build date on my 71. I took the hood and support off and everything worked as it should. You will see in the pictures the support looks to be the same as yours but the bolt holes on the hood for the support are a much wider distance. Somewhere back in time there was work done on the front end so I can’t be 101% sure this is the original hood.
Reactions: Prab
Fred J
Oct 23, 2016
19
16
Awards
3
Sault Ste. Marie, Ontario Canada
Corvette 1973 & 1976
Prab
My 73 has the same 14" from front of hood to bracket....
Prab
Mar 15, 2018
26
2
Awards
2
Edmonton
1971 Corvette
AB
Hi,
Thank you for sending the picture Norm07, that really helped to clarify a few things.
