my to do list is quite long. I am having a great time with this car. I was in a very bad work related vehicle accident a couple years ago, and it's taken a gargantuan effort to get myself back to the point where I can have short bursts of enjoyment with physical activities... Being in pain all the time really drains all enjoyment out of life, let me tell you! But having this car on the back burner for so long has been a great motivator. And though I am quite limited in not only what I can do, but for how long I can do it -- the benefits of enjoying doing the things you love to do are frankly invaluable in terms of a therapeutic device. So enjoy and value all that you have while you have it!
TODO:
-paint all metal parts removed from car before reinstalling
-POR15 hi temp paint on headers & bottom of fuel tank
-repair fiberglass on pass cargo compartment box & spare tire carrier
-clean and repaint spare tire carrier
-send spray paint up into areas I cannot reach that are visible while underneath the car
-finish adding stick on heat shields to trans tunnel and lower firewall
-detail & paint engine bay
-fix/replace washer fluid pump & reservoir tank
-fix/replace coolant recovery tank
-install new polyurethane suspension bushings with silicone grease & ptfe tape
-lube / inspect all ujoints
-lube / inspect trailing arms
-install parking brake rebuild kit
-install SS brake lines
-flush & bleed brakes
-install new shock mount lower arms
-relocate parking brake cable bracket from side to top of trailing arm
-paint trailing arms
-install koni adjustable shocks
-install new diff crossmember bushings
-fill diff with gear oil & limited slip additive
-fill trans torque convertor with dex6 and install
-source rear sway bar setup & install
-reinstall 360lb composite monoleaf & differential with new snubber bushing
-install halfshafts
-replace lower speedo / tach cables
-determine which speedo gear color needed for my setup with the 3.70 gears in a 200r4 trans
-choose fixed or flexible trans dipstick
-install 200r4 trans with new trans bushing & 2500 stall lockup convertor & new flex plate & fluid
-install braided trans lines & trans cooler
-install rear driveshaft
-fix hard fuel line cut by PO by removing rubber line & adding couplers
-rebuild 355 cu.in. sbc
-remove pilot bushing
-install engine & headers
-install Pypes stainless exhaust kit & Flowmaster FlowFX mufflers
-install hi torque starter
-install engine accessories
-source and install dual electric fan setup with freshly rebuilt radiator
-wire it all up
-perform engine breakin procedure & confirm AOD TV cable setup
-replace seat belts
-repair & paint seat backs
-repair pass seat back button
-replace negative battery cable & add engine & frame grounds
-test all wiring circuits & accessories / options
-rebuild cruise control transducer & replace upper cables & confirm proper operation of speedo & tach
-rebuild / replace clock
-install AOD shifter gate kit
-locate Lectric Limited proper ohm head temp sending unit or buy variable resistor device & calibrate with temp gun
-fix door sag & locks & lube power window gears & confirm door grounds & wiring are good & add power door lock actuators/alarm
-test horn in engine bay & fix horn button on steering column
-buy stock looking stereo with modern upgrades
-buy & install rear deck sound bar system
-test & run rear defrost wiring and switch
-detail interior
-install front air dam
-install wiper cowl cover & modify to work
I'm sure there's more there to add, once I get to an area and find more things wrong... y'all know the drill ;-)
