Heater Control valve by-pass L-98
Darrellg1
Active Member
Nov 27, 2017
107
104
43
53
Surrey BC
1987 Corvette coupe
#1
Hi all and Happy New Year!!
I THINK my heater control valve took a walk as I HAD TONS of heat, now none. I changed thermostats, and did a by-pass of the Throttle Body heater while I was in there as it wasn't done yet. (Cut out the Air filter louvers too on the filter top.) Also MAF Screens and heat sinks. A bit peppier and happier now.
Is there a way I can by-pass the heater control valve?
Darrellg1
Active Member
Nov 27, 2017
107
104
43
53
Surrey BC
1987 Corvette coupe
#2
Hi all....
I got heat back, bypassed the heater control valve till Corvette Specialities gets my new one in. I also reverse and forward flushed everyhing. heater core, block, and rad. the fellow that owned the car before me did not take care of the beast. i found a bunch of rust in the coolant which turned out to be mostly water.
nascar03
High RPM Poster
Jan 27, 2009
2,544
1,439
113
65
Township of Langley, BC
www.riversidecorvetteclub.org
1975 coupe/2003 vert
#3
Good news Darrell....
Graham
Black 03 Z06
High RPM Poster
Oct 30, 2013
4,993
3,367
113
Haliburton, Ontario
2003 Z06
#4
Well done Darrell. :thumbs:
Good luck with the installation of the new part, at least you know what the issue is. Heat. We could all use some of that right about now.:cool:
ddgermann
High RPM Poster
Jul 1, 2017
1,571
2,076
113
Edmonton
2017 3LZ Z06 Z07
#6
Hi all....
Looks like you’ve made good progress on you Corvette Darrell. All the things you were battling with are all getting sorted out. You should be ready to relax and enjoy come spring. :thumbs:
