Fire22
Member
I installed a new hazard warning switch today as well as a column lock bypass, I am happy to say no problem with either install. I was having intermittent problems with the turn signals last year. I found out through some research that the hazard warning switch could be the problem, sure enough if I had the problem I could hit the hazard switch a couple of times and the signals would work.
I installed the column lock bypass to avoid being stranded, I have read that the column lock can be very troublesome so I invested the $49 usd for some piece of mind.
Removal of the console was easy and revealing, one of the previous two owners was a messy smoker, there were cigarette ashes all over the tunnel and in proximity to the ash tray. This was a good chance to give those areas a thorough cleaning.
Tomorrow I am going to change the spark plugs and wires. I bought AC Iridium plugs and GM Performance red wires.
