my C6 convert is a bear to backup with the top up, just wonderin if anyone has installed a b/u camera and where did you place the monitor? What is the best camera to use, preferrably wireless? I have nav so I don't want to replace the radio.
Haven't had to install one vt but there are several on the market that use a replacement rear view mirror as the monitor ...If I'm not mistaken, there's a GM one available that has the Onstar in it as well as the monitor.
The lockpicks is doing it to the 2011 model, 2012-13 had additionals speakers so the harness supply with it do not fit. I did call the company in Florida and they said they will not produce a unit for the 2012-13, to small market. I did found another systeme on the market but it was 800 USD, so better change the unitI am not sure if you could fit a C6 factory Nav with back up camera. Does it exists? Bought my C6 with an aftermarket Kenwood with the backup camera, Carplay, etc. It is definitely an awesome option as it is sometimes difficult to backup.
Cheers
Interesting I like it what brand name ??? where did you purchase it ??? heading for Moncton next weekI have the OEM Nav system in my 06, and wanted a back up camera, but didn't want to just have a stand alone monitor somewhere to be an eyesore.
My solution was to remove the driver side sunvisor vanity mirror assembly and install the monitor in it's place. I used the vanity cover, cut it to the same shape as the monitor, and mounted it in the cover. The cover is then attached to the sunvisor using clips.
It worked, out of sight until you want to use the BU camera, and looks OEM.
Here is a pic.
