DenisC8
its will only be visible when the tonneau cover is open in service modeFinally! This should have been available on day 1.
Guessing this puppy will set you back $2K as a retrofit.
Is it just me, or does the engine cover look like it should be mounted backwards, so that the lines flow from front to back aerodynamically. Not the way it is installed in the pics.
Yes, you can see that in the photos. My cost estimate reflects that.its will only be visible when the tonneau cover is open in service mode
tonneau cover itself will not have a window
The GM version still has insulation under it, and is apparently a double pane (with an air gap) window. That tells me GM is still concerned about the effects of heat on the roof over time. The aftermarket plastic cover has no insulation at all.why not just buy a aftermarket completely clear one for $600 USD?
Me neither, but others do. I love showing off the car.As a coupe owner I just don't get it. I looked at my engine through the glass on the first day I got it and never looked again. I just don't find it that exciting to look at my plastic engine cover.
