When was the last time you had a blowout on the highway with any modern vehicle? Do you have a tire plug kit with a mini compressor? Are you capable of using the plug kit? The answers to these questions will lead you to the right answer for you.I have loved the idea of run flats up until recently. I learned that they cannot be fixed if there was a puncture. If that is true, sure, you can get to the tire shop on them, but then what. It seems extremely unlikely that they have your tire in stock, so you would have to leave your car and hope they can access a replacement tire in a reasonable amount of time. If they were non run flats and you have an issue, at least they might be able to be repaired, and if not, a replacement tire would likely be more accessible. The downside to that is I guess you would need a tow to get to help.
If this is not accurate, please inform, as I was contemplating getting non run flats when the time comes for replacement..
That is good information, Thanks Ross.All of the Michelin Piot Super Sport ZP tires as supplied on all C7's, including the Cup 2's, can be successfully repaired with the following restrictions:
1 - The damage is only on the tread section of your tire (sidewall damage ruins a tire immediately) and/or
2 - The puncture is no greater than ¼".
In addition, the proper way to have a tire repaired is to patch the tire from the inside so as fill the puncture hole. Do not have your tire plugged. Ever. Plug repairs do not involve taking the tire off the wheel for a proper inspection. A plug is simply inserted into the punctured area, making it unreliable. Insist on a full inspection and have your dealer demount and internally as well as externally inspect the tire, patch and fill the repair on the inside of the tire.
This information comes directly from the Michelin website.
C7 owner's have been successfully repairing their run-flats since the C7 was born with no ill effects. Many owners are even tracking their cars having used the proper inside patch repair method. In my opinion, the MPSS ZP offers the best combination of performance, reliability and safety for our cars. I will continue to use Michelin ZP's in one form or another.
As for a good choice for replacing the run flats, the Michelin Pilot Sport 4S seems to be the tire of choice. Just make sure that you have a temporary method of sealing a puncture and inflating the tire. Remember, chances are good that you will probably have to replace the conventional tire after a puncture if driven even a short distance.
Best regards
Ross
There are pages of these run flat conversations if you care to search the forums. Lots of different opinions.What was wrong with your run flats?
2019 Stingray
Someone wanted to sell you new tires. Just after we bought our 2005, I ran over a nail. I too had heard that they couldn't be plugged and patched. I took it to my local garage guy and he laughed. Sure they can be repaired, the same as any other tire. That was 7 1/2 years ago. I still have them sitting at home and still holding air.I have loved the idea of run flats up until recently. I learned that they cannot be fixed if there was a puncture. If that is true, sure, you can get to the tire shop on them, but then what. It seems extremely unlikely that they have your tire in stock, so you would have to leave your car and hope they can access a replacement tire in a reasonable amount of time. If they were non run flats and you have an issue, at least they might be able to be repaired, and if not, a replacement tire would likely be more accessible. The downside to that is I guess you would need a tow to get to help.
Here is a horror story. Got my first nail in my run flats at 2,000 km. At 4500km I was changing the stock brake pads over to power stops and noticed the other 2 tires had nails in them. So just under 5000 km, 3 out of my 4 tires have been professionally patched. I have been told they will not patch a tire that has previously been patched.
I am dreading getting another nail.
This is insane, I may have to spend huge $$$ on tires with a car with low kilometers.
