ThanksShould be a couple of small plastic cables in the rear compartment above the drivers side wheel well and rear cubby. And one for the doors as well.
pryed it open..put piece tape so i can open it with plastic credit cardTim, did you get it to open?
there has to be? i hopeThis topic made me wonder if there is a release cable in the C7. I have not read anything about it in the manual, and with how “electronic” this car is, if that messes up when you are needing gas, what the hell do you do?
You might wanna read your manual Tim. I’m curious now if you’re aware of the alternate way of opening your doors from the inside if you have a sudden loss of power and the button on the grab handle does nothing ?there has to be? i hope
thanks so much my friendYou might wanna read your manual Tim. I’m curious now if you’re aware of the alternate way of opening your doors from the inside if you have a sudden loss of power and the button on the grab handle does nothing ?
You don’t want to be in a situation like the old guy and his dog in Texas a few yrs back.
Texas man, dog, die inside Corvette when doors and windows won’t open
A 72-year-old man from Port Arthur, Texas, died inside his dream car when the lock system malfunctioned and he was trapped inside his 2007 Corvette with his dog, Leia. James Rogers and his pet both…www.nydailynews.com
On the floor as shown in my car,you’ll see this plastic handle. That releases the door if there’s no power. There’s one for the passenger side in the same location.
This happened to my wife a couple years ago when we first got her vette. Once she got in the car the battery went dead. She couldn't get out because we did not know about the manual door opener on the floor. She was in the car in the garage with no cell phone. After sitting there for a couple minutes she thought about the roof coming out, and was able to climb out of the car. She said she was thinking about trying to kick the window out before she thought about the roof. Once the roof was cracked open she felt a instant relief.
Although this is a C6 question, Re: wondering about the C7 Fuel Door:This topic made me wonder if there is a release cable in the C7. I have not read anything about it in the manual, and with how “electronic” this car is, if that messes up when you are needing gas, what the hell do you do?
My understanding is there is an electrical locking mechanism ( with plastic actuator rod) that engages into a receiving hole when the car doors are "locked". I've read a number of times that some C7 owners have experienced the dreaded "locked fuel door". This electronic lock mechanism activates a locking pin and its when this locking rod gets stuck the fuel door wont open. One fix is to install a cheap pushpin to block the pin receiver hole so the lock wont engage at all. Note the door still clicks closed.Although this is a C6 question, Re: wondering about the C7 Fuel Door:
The C7 does not have appear to have anything "grabbing" the fuel door, you can open it with your fingers if you try.
I think it's just a simple spring pop out that is electrically disabled when the C7 is locked so that you can't push for it to pop out - but you can still finger-pry it open.
I stand corrected ... I didn’t think to open the fuel door and lock it with the remote. Did it and there is a pin that pops out that will lock the door from being pried open ...My understanding is there is an electrical locking mechanism ( with plastic actuator rod) that engages into a receiving hole when the car doors are "locked". I've read a number of times that some C7 owners have experienced the dreaded "locked fuel door". This electronic lock mechanism activates a locking pin and its when this locking rod gets stuck the fuel door wont open. One fix is to install a cheap pushpin to block the pin receiver hole so the lock wont engage at all. Note the door still clicks closed.
whatI stand corrected ... I didn’t think to open the fuel door and lock it with the remote. Did it and there is a pin that pops out that will lock the door from being pried open ...
ordered new fuel door actuator for my C6...should be in next Tues..what
Don’t check it out the way I did itwas trying to,figure,out the,pin thing so,I could do,it
sorry for,the,confusion
