Hey guys,
Is it possible to separate the wiring in the front running light from the turn signal? I want to run a led running light on the existing run circuit but have the turn signal operate separate. Basically split the 1157 circuit if the makes sense.
I can wire the running light separate on its own switch, that's fine but I only want the turn signal to flash when needed and not be on all the time as run.
I hope this makes sense lol, any insight would be great
Thanks
Thanks
