Front lift reservoir cap leaking. New one on order.
To inspect you have to remove the cowling covering the battery.
When removing the trim cover, broke two tabs off. (bigger hammer).
Solution is install proper fittings NAPA p n 665-2111
Grind off remaining stub of broken tab, drill small pilot hole mid point where the fitting was. Easiest to locate the pilot hole before grinding off all of the broken tab.
Then drill bigger hole (7/32?)to accommodate a tight fit for the new fitting.
