D
dannyyaro2000
I'm New Here
Jun 19, 2012
2
Edmonton
1977 coupe
I have a 1977 and my fender clearance is at least an inch higher at the front than it is at the rear, i would prefer to have it the other way around any suggestions on what is the cheapest and easiest way to accomplish this without sacrificing handling and ride?
I would start by putting a big block in it.:D That'll get the springs to settle.
Honestly though, I'm not sure. The best part is that this increases my post count by one.
I would maybe start here: http://www.vbandp.com/ and look at what suspension packages are offered if you want to upgrade the suspension. As for simply adjusting it to get it to sit lower...... that is a good question. I'm familiar with the C5's and 6's but that is where my knowledge ends. I would like to hear what others suggest.
I'm sure Manny (Nasty98) could help you out.
Eaiset way would be to put shorter springs and shocks in the front .
With the transverse leaf in the rear they do tend to sag a little as they reach the golden years.. New springs in the rear should level it out.. I put gas shocks in the rear of my 81 and it sits pretty level now.
I agree, start with the rear suspension and make sure it is up to snuff. My car has had the rear spring replaced and it sits perfectly level now.
