I did a search on Foam Cannons however I couldn't find a thread that really provided me any clarity with regard to recommendations or pros and cons.
So with that, what are your thoughts? I have a pressure washer and I'd be interested in your findings. Which Foam Cannon to buy and are they any good? As well what soap do you use and any other recommendations.
My understanding is a Foam Blaster will prevent the swirls you might otherwise get with standard washing.
I should say right now I don't use buckets, I soak a wash mitt and add soap directly to the wash mitt. The car is thoroughly rinsed then washed and rinsed again. Always top to bottom, then rinse again and finish with a chamois.
Wheels always with a separate wash mitt.
Looking forward to your responses.
