- Jan 11, 2009
- 11,104
- 1,983
Right now I am using.....or should I say, attempting the repair on a '91 GMC Sonoma. 4.3L Automatic 4x4.
Once the engine warms up, it dies when stepping on throttle. It starts out as a little bog, then keeps going, then the bog lasts longer until pressing on the gas simply kills the engine.
Parts replaced: Distributor and spark module, ignition coil, air idle control valve, map sensor, egr valve, some part that connects to the egr valve, and throttle body and injectors, fuel pump, fuel filter, replaced cat and muffler.
Yesterday I took the intake off and cleaned all the egr passages. The intake to head passage was 40% blocked. The passage from the egr valve to the intake where the air goes in was 100% blocked. Cleaned this and it helped but the truck still dies when hitting on the gas however it is more intermittent than before. Once it started acting up before it was done, now it can recover every once in a while and you can keep it going more easily but it definitely has the same issue.
We believe it is getting fuel while in the bog as we had it inside and could see fuel spraying into the intake as the engine was dying. But all thoughts are welcome! Quite stumped why this is happening.
One other clue.... We'll pull it in the shop right after it's been doing this, start it, most of the time it runs fine, revs, we can load the engine with it in gear, seems fine. Go outside, within a minute it's bogging and dying.....seems to only happen when driving and in a stop and go scenario.
