Black 03 Z06
16,898
38,066
Haliburton, Ontario
2003 Z06
This has been an issue for many C5 owners. Thought I would pass it along.
- OE fit, finish, function and appearance once installed.
- Includes instructions and installation tool for use with OE fasteners.
- Maintains same throttle response as OE.
- Replaces a failed APP Sensor with a new part instead of used or “refurbished.”
- Solves the problem of failing APP Sensor causing the car to enter “limp mode.”
- Eliminates P1275, P1280, and P1285 DTC Error Codes from failing APP Sensors.
- Works with all LS1 / LS6 Corvettes with a 9 Pin APP Sensor.
- Allows our customers to replace only the sensor, not the whole pedal assembly.
Fitment: 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004 C5 Corvette
https://www.rpidesigns.com/shop/item...r-and-harness/
