First Canadian C5 ever that have airbag with steering wheel controls on C6 working with top Kenwood unit
Link...Is that a C6 steering wheel with the C5 emblem attached or is it a C6 wheel with the entire C5 airbag section? I didn't know the two wheels were that similar.
That C6 steering wheel on C5. ...they don't fit on C5 you need to change and put the C6 upper steering shaft to C5 to make it work. .. l should to to write and post how to install this before long time but I forget about it ... And that not C5 airbag because they don't fit with C6 steering wheel that airbag from different car to make it fit but even airbag from C5 it's completely different from C6 system ... airbag C6 it's called two stage and C5 it's called 1 stage .. ..the problem is if you put C6 steering wheel you have 2 choice only or you make airbag working but no steering wheel controls or opposite ...but after 1 year working heard with genius from USA finally we make the first car in the world C5 that have airbag with steering wheel control work together
