firewall wire retainers
teamo
1975 Corvette Coupe
Hi All,
I am trying to figure out exactly where to rivet the wiring/vacuum line clip into place. It was loose when I removed the forward harness. I've searched online and some of the pictures that I've seen show what seems to be a bolt with a nut and some appear to be riveted in different locations. There is a hole in the brake pedal bracket that is slightly off center. Would this be the correct place to drill up and through the top for this rivet? The AIM comes up empty for this one.
Hello Teamo. Not sure what year you have but mine is a 69. The line clip is riveted in that location. the rivet is aprox. 1.5" from the bottom edge and .75" from the edge. Hopefully this helps
Hello again. Yes, when I said bottom I meant the horizontal section above were the booster bolts to. Not the section the the booster bolts to.In the corner on the section that the arrow is pointing at in your picture. Hopefully that is a little clearer.
