Can anyone recommend a glue they used that worked well to reattach the fiberglass to the frame above the headlights (it’s common that they detach on older corvettes I’ve heard)
I'd suggest using Fiberglas epoxy paste with a bit of fiberglass chop mixed in. I did a repair to my 1972 car using this method and I held together great . Just make sure you clean both sides down to the fiberglass surface.
If it matters anymore.....I used a SMC body panel epoxy (probably the same or similar to the fibrglass epoxy!) Came in a silicone tube with a mixing nozzle and man did it take effort to get it out.
