Engine Bay lighting mod
2019 Stingray
BC
Question. Has anyone that has factory install engineer bay lights purchased the small wire harness to put between the two factory plugs ? So that you can run your lights with the rear window defroster button. If you have is it worth the $85.00 USD.
Thank You if you have any feedback back.
Although they have to be recharged via usb-c they hold a charge a long time. How often do you open the engine cover? Work on motion and are magnetic. Quite bright as well and the price is right. Just a thought.......and they are on sale right now.
