Hey Guys.
Well another winter’s underway and I have some more projects in the works. I decided to start a post showing the work I’ll be doing. This includes a differential rebuild, new custom rear upper strut install that a racer from BC made for me, A/C install, custom rear corner 6x9 speaker boxes for some new polk speakers, and a front one piece super spoiler.
The differential is the first stage of my winter build and I’m getting a later start on it because I was busy rebuilding a T56 Magnum for a guy to put in his 68 Camaro.
I’ll be rebuilding the diff with Tom’s 30 spline side axles, 30 spline spider gears, and new clutches and 400lb springs. I wanted to get the assembled unit from Tom’s but unfortunately they don’t have as much as they use too so that’s why I’ll be rebuilding my original posi. Although I have heard that the strongest cases were from 72-79 as they are thicker. I’ll be polishing the case to prevent cracks. I’m also going to swap out my 3.55 gears for Richmond 3.90’s as it’ll give me better acceleration and a useable 6th gear for cruising. My front differential mount also needed to be modified as the T56 caused the driveline angle to be thrown off and I don’t have enough adjustment on the mount to get it within specs. So that was just finished today and I’ll be picking it up tonight.
I have all of my parts on order so I’ll be starting the rebuild soon.
