Question darn dead battery today nov 26 2018
Jeffer2013
C7 Owner
HOT Dealer
Aug 1, 2013
749
667
alberta
Best answers
2016 Base DSOM
Province / State
Alberta
Reactions
658 9 0
#1
went to move the 2016 out of the way so Ican park the corvette on top the lift and have the lower class mustang on the ground,
No luck dead
So I put the trickle charger on it for 26 hours and nothing
Put a big charger on it at 2 amps and after 20 seconds it began to click like a cat purring for about 4 seconds
and the pause for one second and then click for 4 seconds
what the heck is going on, could not get into glove box, electric is dead,
that is where the manual is
and had to use the key in the rear and the door pull.
Do I try a smaller battery charger tomorrow?
Jeff the lonely and cold
ddgermann
6000 RPM Poster
Beta
C7 Owner
Jul 1, 2017
3,143
4,360
Edmonton
Best answers
2017 3LZ Z06 Z07
Province / State
Alberta
Reactions
4,336 24 0
#15
I'm not familiar with the "7200" but most maintainers are not really designed to bring a battery back from total discharge (At least not in much of a hurry).The math is quite easy.... Battery charger amperage is the charge rate in Amp hours (Ah).... Thus a 2 amp charge is charging at 2 amps per hour. A vehicle battery size can be anywhere from 45 Ah and up to over 100 Ah. (not to be confused with CA or CCA ratings) so say 100 divided by 2 equals 50 hours of charge with a 2 amp charger from dead to full (assuming the battery is in a condition to accept the charge. A lot of maintainers note in the fine print directions (yes... there were directions that came with your maintainers....lol...) that they are not really designed to charge a dead battery.
Eric some chargers are indeed designed to bring a battery back from full discharge as well as condition the plates with cycles of high amps to move the sulphate off the plates along with monitoring the battery performance and reaction to the conditioning. Due to the expensive batteries I was eating up in my Hummer, I have spent a ton of time researching this aspect of the “maintainer” vs the “smart charger”. The 7200 is just one of many that have this capability. I also have a different one in my garage that will provide all this and a boost function with a timed and monitored high amp push. So lots of different options on these things depending on what brand you buy or just what you’re looking for in a Smart charger/maintainer/booster/...etc
The day is long gone for plugging in the low amp charger and only recovering a % of the battery capacity after a full discharge. The new generation chargers are really quite remarkable in their capabilities.
XFIRE82
HOT Dealer
C4 Owner
C3 Owner
Oct 24, 2014
849
917
Krydor, Saskatchewan
Best answers
1
Reactions
904 13 0
#2
did you put a volt meter on the battery posts to actually confirm it is dead ? maybe you got a bad post connection ? take one cable off and put a charger on it and see if it decides to take charge.
OP
OP
J
Jeffer2013
C7 Owner
HOT Dealer
Aug 1, 2013
749
667
alberta
Best answers
2016 Base DSOM
Province / State
Alberta
Reactions
658 9 0
#3
the charger I tried was the crappy tire model 01115864 a big one, might try to disconnect one post but thought a charger should work
do not want to screw up the electronics
OP
OP
J
Jeffer2013
C7 Owner
HOT Dealer
Aug 1, 2013
749
667
alberta
Best answers
2016 Base DSOM
Province / State
Alberta
Reactions
658 9 0
#4
don’t have a volt meter beyond my pay grade
Rruuff Day
I Just Can't Help Myself
Beta
C7 Owner
HOT Dealer
Top Poster Of Month
Aug 30, 2014
5,741
5,219
Pine Lake, Alberta
Best answers
C7 3LT ZF1
Province / State
Alberta
Reactions
5,205 14 0
#6
Jeff. Not to say a battery that was working fine a few weeks ago won't totally crash and not take a charge at all, but it's still worth a shot at trying to charge again. 2 amp is still just a trickle. My advice (for what it's worth), would be to put a 10 or 20 amp charge on it for a few hours. If your charger was born in this century it should recognize when (and if) the battery reaches full charge and go into float mode and not overcharge. If the battery doesn't want to take a charge, and if your man size charger has a gauge on it, it should tell you if your battery is accepting a charge before too long. The charge rate will typically slowly reduce as the battery charges. (At least mine does).
OP
OP
J
Jeffer2013
C7 Owner
HOT Dealer
Aug 1, 2013
749
667
alberta
Best answers
2016 Base DSOM
Province / State
Alberta
Reactions
658 9 0
#7
Ok will try that gh to move the car
ddgermann
6000 RPM Poster
Beta
C7 Owner
Jul 1, 2017
3,143
4,360
Edmonton
Best answers
2017 3LZ Z06 Z07
Province / State
Alberta
Reactions
4,336 24 0
#8
Jeffy I was not really clear above. I would disconnect the battery from the car before charging it.
Better to be safe than sorry with the current from the charger being rammed toward the electrical system.
Really if you don’t have a larger intelligent charger, treat yourself to an early Xmas gift man. They will do wonders for the battery and take all the guess work out. They charge in cycles and tell you the overall condition of your battery through the process. They will also let you know if your battery is toasted.
There are many brands that do a great job for about the price of a new battery. Well maybe a little more but you get the point.
D
Rruuff Day
Beta
C7 Owner
HOT Dealer
Top Poster Of Month
Aug 30, 2014
5,741
5,219
Pine Lake, Alberta
Best answers
C7 3LT ZF1
Province / State
Alberta
Reactions
5,205 14 0
#9
D
Derek has a good point there Jeff. A 10 or 20 amp charge is not close to what a standard 110 amp alternator would put out for a nearly dead battery but better safe than sorry is advisable all the time. Unhook your battery prior to charging.
OP
OP
J
Jeffer2013
C7 Owner
HOT Dealer
Aug 1, 2013
749
667
alberta
Best answers
2016 Base DSOM
Province / State
Alberta
Reactions
658 9 0
#10
got the mustang on tender
got the camera on tender
disconnected corvette battery and got it on 20 amp charger for the last couple of hours and will continue until tonight
then it goes on a regular charger until the am then back on the 20 amp larger charger for a couple of goes of 135 minutes each
then put it back together and if it starts move it 9 feet and run the corvette plug in trickle mcjarger for the winter
crappy tire has to 7200 charger coming on sale dec 7th or so for 32 bucks off so 115 instead of 145 plus gst
does the 7200 really bring back most batteries from the dead, if so then I better have one
for the record this corvette never goes soft when left for up to 2 months so this was a surprise but it is unheated side of small garage
later Jeff. and thanks
SN-III
Making this Day Count
Beta
C7 Owner
HOT Dealer
Oct 10, 2016
3,286
5,190
YYC - alBEERta
Best answers
1
His & Hers C7s
Province / State
Alberta
Reactions
5,132 58 0
#11
ddgermann
6000 RPM Poster
Beta
C7 Owner
Jul 1, 2017
3,143
4,360
Edmonton
Best answers
2017 3LZ Z06 Z07
Province / State
Alberta
Reactions
4,336 24 0
#12
It will likely start up after that effort Jeffy. The maintainer you’re buying does all that for you automatically. But I’m impressed with your effort.
Yes the 7200 will do all that for you and will recover a battery from totally flat if the plates are not completely covered over with sulphates. In some cases nothing will bring them back. But yours is new enough and never been flattened before so it will likely condition back close to 100%.
Jeffy remember to grab the plug in connection for your car as it will work great as a year round smart charger too. They sell the accessories for these chargers as well.
Good luck man.
OP
OP
J
Jeffer2013
C7 Owner
HOT Dealer
Aug 1, 2013
749
667
alberta
Best answers
2016 Base DSOM
Province / State
Alberta
Reactions
658 9 0
#13
at 505 pm it says fully charged, will leave a small charger on overnight and see in the am
battery is complicated has anyone looked at theirs, not the normal battery
Jeff
Rruuff Day
Beta
C7 Owner
HOT Dealer
Top Poster Of Month
Aug 30, 2014
5,741
5,219
Pine Lake, Alberta
Best answers
C7 3LT ZF1
Province / State
Alberta
Reactions
5,205 14 0
#14
ddgermann
6000 RPM Poster
Beta
C7 Owner
Jul 1, 2017
3,143
4,360
Edmonton
Best answers
2017 3LZ Z06 Z07
Province / State
Alberta
Reactions
4,336 24 0
#16
Jeff
You’re right Jeffy there are plenty of things connected to the battery. Once you mine down and find it it looks like a regular 12 car battery to me. Although I never pulled mine out.
Picture Jeff? 😂
Rruuff Day
Beta
C7 Owner
HOT Dealer
Top Poster Of Month
Aug 30, 2014
5,741
5,219
Pine Lake, Alberta
Best answers
C7 3LT ZF1
Province / State
Alberta
Reactions
5,205 14 0
#19
Totally agree Derek. Thus the "At least not in a hurry" rider on my comment about "most" tenders . You obviously have a much more advanced smart charger than mine. When I don't want to wait 50 hours, I don't rely on them to do the job..... I hook up the big boy.
ddgermann
6000 RPM Poster
Beta
C7 Owner
Jul 1, 2017
3,143
4,360
Edmonton
Best answers
2017 3LZ Z06 Z07
Province / State
Alberta
Reactions
4,336 24 0
#20
For sure Eric. Some of us simply do not need a charger with these advanced features as the little smart chargers are all the car needs to maintain the battery in a corvette when it’s parked and plugged in. Never does the car get allowed to draw the battery down and it always fully but never over charged. Thus a $30 smart unit is perfectly adequate.
I have 2 vehicles parked for at least a month at a time and one of them is sitting for 6 straight months so in all the trials and tribulations I have aquired simply what I need.
I’m by no means saying what I do is what anyone else must do. Although it may have came off that way. Not my intention.
If I had your Vette cave my situation would be much better. 😂. Of course I would have to make it a bit wider to get the other black beast in there too.
Hmmm if I build it would you and the gang come over and wail out some tunes?
Man that sounds like the best thing that could come out of this thread. 👍😂
It’s all good Man 😀
Rruuff Day
Beta
C7 Owner
HOT Dealer
Top Poster Of Month
Aug 30, 2014
5,741
5,219
Pine Lake, Alberta
Best answers
C7 3LT ZF1
Province / State
Alberta
Reactions
5,205 14 0
#21
Lol...No gang. Just me and whoever drops in to jam with me on the rare occasion...I don't play nearly as much as I should... Just like any other hobby.
And good use of the word "wail".... Often I have been likened to a wailing coyote caught in a leg trap...o_O More so after 3:00 am.... :sicktongue:
ddgermann
6000 RPM Poster
Beta
C7 Owner
Jul 1, 2017
3,143
4,360
Edmonton
Best answers
2017 3LZ Z06 Z07
Province / State
Alberta
Reactions
4,336 24 0
#22
Sounds good to me Man. 👍
