Jcu1287
Jcu1287
Jun 23, 2019
39
47
89074
1990 L98 C4 Coupe
USA
Good morning fellow vette fiends! Quick question.... What is the best switch or kit to buy and install that turns the cooling fan on at lower Temps so it doesn't ride so hot?
Not positive about your model but this should be able to be done through programming your ECU (maybe not the correct box name).
These settings should be analogue and not operating off a switch to work along side your overall engine control system.
Hopefully in 1990 models it indeed is this way for you. Makes it easy to do
Pretty sure I’ve read threads here where guys have done this reprogramming. Just not sure about C4s.
Let us know what you find out.
