Convertible rear glass fix
Firstcorvette
Member
C5 Ontario You're Celebrated Completionist Award
2002 C5 convertible
Hi this is my first post here, has anyone glued in the rear glass on a 02 C5? No one in town will touch it! A new top is out of the question. I used the forum search. I cant be the only one with the glass coming loose? Anyone have someone local? thanks in advance.
I found one post from a while back from a Corvette Specialist that has since retired. Not sure if it's any help but maybe a DIY fix idea..
You need to use cyanoacrylate glues the best one it's called Rhino Glue you can buy it online www.rhinoglue.com make sure do not buy rhino liquid nails
That glue very fast dry you need to apply from middle to the sides but before that you need to have and prepare suction dent pullers to pull the window back same place after you apply the glue immediately and leave it for one day
Where are you?
I bought the Rhino glue. I am looking for the suction cup clamps. Will return soon with an update.
Update. It worked!!!!
I would highly recommend a professional to do the job right. I’d try Crystal Glass windows see what they have to say. They do replace windshields 🤓
Crystal glass is a little bit far away from me.
